I am trying to configure a uart2 in TWR-K53N512 from its expansion port(TWR-ELEV primary pls check the PDF:DRM141(freescale Kinetic TWR-K53N512))
I am in a confusion that how to setup the pll_init(); //default core clk:50Mhz,Ref clock=Xtal_8 with respect to example program of hello world
It would be much help full if someone could tell how to setup pll_Init
You can reach via skype :avarghese_i3
