Hello Everyone
I am using freescale KL26Z256 controller. I required to create separate segment of flash memory which is independent with firmware code.
So is it possible to create such segment which is totally independent with bootloader and firmware?
waiting for your kind response.....
Thank you
Solved! Go to Solution.
Customer can use software to emulate a Flash segment to store variables. While, that segment could not be split from Flash memory.
Wish it helps.
Ma Hui
Wish it helps.
Ma Hui
