Can't get any USB Interrupt
ソリューションへジャンプ
2,001件の閲覧回数
georgschmidt
I'm trying to get the USB_FS-Module running in Device-Mode on the TWR-K60F120M System.
During initialisation I activate the USB-Reset Interrupt, the global USB-Interrupt in the NVIC and assign an ISR.
Then I apply a reset to the USB-Module by setting the USBRESET-Bit in the USBTRC0-Register.
But I don't get any Interrupt neither after powering up the tower nor after applying an USB-Connector to the TWR-SER-Module.
What do I do wrong?
Thanks for help,
Georg
1,882件の閲覧回数
georgschmidt
I have found my mistake.
I didn't use the proper clock settings in the SIM.
Nevertheless, thanks for reading!
Georg
2 返答(返信)
1,883件の閲覧回数
georgschmidt
Georg
1,882件の閲覧回数
Monica
Senior Contributor III
Sorry for the late reply, Georg, but it's great that you found and corrected the flaw...keep it going! :smileywink:
We'll be around!
Regards.
