Can not connect to targe(frdm-k64) using j-link
2,304件の閲覧回数
hxc
   I would like to program frdm-k64 using j-link tools, but enter problem.
   It can not connect to my board, and say that:
Xiangcai.
ラベル(2)
7 返答(返信)
2,155件の閲覧回数
jingpan
It seems computer has established connection with openSDA jlink. But openSDA jlink can not access K64. I think there are few cause for this problem:
1. If you didn't cut j8/j11/j12 before, you can use a standalone jlink to check if K64 is ok.
2. If K64 is not ok, please check the power supply.
3. If K64 is ok, then maybe openSDA has problem. Can you tell me your Windows version and openSDA version?
Jing
2,155件の閲覧回数
hxc
Thanks for your reply~
I did use a standalone jlink on the JTAG(J9) connector, and it can not connect to FRDM-K64.
2,155件の閲覧回数
jingpan
Have you checked the power supply?
2,155件の閲覧回数
hxc
Sure, but it doesn't work. And it work fine on the other board. I can not find it out.
2,155件の閲覧回数
jingpan
You mean you have more than one frdm board and other board works fine?
2,155件の閲覧回数
hxc
Yeah
2,155件の閲覧回数
jingpan
