Can Kinetis K60 MII RXER, CRS, COL pins that are unused be repurposed?
708 次查看
thomasmiddleton
I'm trying to figure out whether I can repurpose the MII0_RXERR, MII0_CRS, or MII0_COL pins in my design on a MK60FN1M0VMD12. The pins presently would not be connected externally to anything but ground. I'm connecting it to a switch which has an MII port and will not have those signals.
Can any of those pins be set to another function (such as FTM, or IO) rather than seemingly being wasted inputs from ground?
Tom
标记 (3)
625 次查看
mjbcswitzerland
Specialist V
Hi Tom
If you don't need these pins for your Ethernet connection you can use them for any other of their possible functions.
Mark
Complete K60 solutions, training and support:http://www.utasker.com/kinetis.html
Kinetis K60:
- http://www.utasker.com/kinetis/TWR-K60N512.html
- http://www.utasker.com/kinetis/TWR-K60D100M.html
- http://www.utasker.com/kinetis/TWR-K60F120M.html
- http://www.utasker.com/kinetis/ELZET80_NET-KBED.html
- http://www.utasker.com/kinetis/ELZET80_NET-K60.html
