Can I tell if VBat is good on my K60
997 次查看
OliverSedlacek
I'm using an MK60FN1M0VMD12 and I need my software to check whether the battery for the RTC is good/present. I'm sure there's a register bit somewhere that I can read, but I don't see it in the RTC description. Can someone point me to it?
Thanks in advance, Oliver
标记 (3)
858 次查看
egoodii
Senior Contributor III
Technically, the TIV (Time InValid) flag tells you if VBAT_POR has occured due to Vbat falling below the minimum threshold per the electrical specs.
