I was able to flash my MK64FN1M0xxx12 MCU using JLink until I flashed some sample code which seems to reconfigure one of the pins used for the debug connection. Is there any way to reset the pins without being able to connect?
The JLink commander error:
Device "MK64FN1M0XXX12" selected.
Connecting to target via JTAG
InitTarget()
Connect Under Reset
Connect Under Reset
Connect failed. Resetting via Reset pin and trying again.
InitTarget()
Connect Under Reset
Connect Under Reset
****** Error: InitTarget(): PCode returned with error code -1
InitTarget()
Connect Under Reset
Connect Under Reset
InitTarget()
Connect Under Reset
Connect Under Reset
Cannot connect to target.
