Can FlexBus be connected to SRAM like this?
1,692 次查看
ljjtczr
FlexBus's FB_AD1~FB_AD18, which should  been connected to SRAM's A0~A17 .
The PCB board has been completed, and then we need to replace the SRAM . The new SRAM's address line is one pin less than the old. It has changed a NC pin in the middle of the address line.
So FB_AD1~FB_AD5 is connected to A0~A4, FB_AD6 is connected to NC useless, FB_AD7~FB_AD18 is connected to A5~A16. I want to ask, can it be used normally?
标记 (1)
4 回复数
1,487 次查看
miduo
What part number you mentioned?
1,487 次查看
ljjtczr
before:
now:
1,487 次查看
miduo
I mean the Kinetis part you connected with this SRAM.Thanks.
1,487 次查看
ljjtczr
MK64FN1M0VLQ12
