Build Error CW 10.1 MQX RTOS
1,361 次查看
Lertets
I'm currently trying to compile a c++ project using the MQX RTOS but I continue to encounter the same error, it is:
illegal overloading '__set_BASEPRI(unsigned long)
make: *** [Sources/main.obj] Error 1
This occurs for both the sample blinking program (which works fine when compiled as a C project) and a blank MQX project.  If anyone has any insight into the problem I'd greatly appreciate it.
1,219 次查看
Dekiru
Are you using the Professional edition? Only that edition supports for C++.
All other editions including the free one support for C but not C++
1,219 次查看
Lertets
Thanks for your response.  I am using the evaluation edition but was given a 45 day license to try out the functionality by a local freescale rep.
