Hi.
Ask questions on the FRDM-KE06Z board.
After purchasing, when I insert the USB cable, the green LED of D5 blinks 7, 8 times and then goes off, and blinks 7 and 8 times repeatedly. Is this normal?
It does not change even if the reset button is pressed, and nothing changes even if SW2 and SW3 are pressed.
Is not a 3-color LED control application installed?
If this condition is wrong, please tell me how to improve from this condition.
Thank you.
jun
解決済! 解決策の投稿を見る。
Are you using Windows 10?
If yes, see Recovering OpenSDA Boards with Windows 10 | MCU on Eclipse and search for "error code". It looks like Windows 10 has affected your bootloader on the board.
That above article describes how to recover the board.
I hope this helps,
Erich
I hope this helps,
Erich
It went well.
Thank you very much.
jun
