Anyone could help, to find schematic of PK60N512VLL .
fengxu
I'm new work with Kinetis.But I could't find the schematic of PK60N512VLL100 for development.
I only find PK60N512 of BGA connector but I couldn't find 100 pin LQFP part.
I went through all documents but still didn't find  schematic of 100 pin LQFP  (PK60N512VLL100)
Could anyone help me.. thanks a lot.
I am not sure, if there is not schematic for 100 pin LQFP or just  because I didn't follow the right path to find it.
my E-mail: liuxulei@bu.edu
anthony_huereca
The schematic for the LQFP part can be found in the data sheet for that part, in section 8. The data sheets are on the Documentation tab for each particular Kinetis family.
Note the new part numbers for Kinetis parts, so the K60N512VLL100 is now K60DN512ZVLL10
-amh
fengxu
hi, amh
thanks for reply.
but I only find the K60 100 LQFP Pinout Diagram. Could I find anything relate to application information or schmatic hint that I could reference them into my project.
thanks a lot, because I try to found those information, but I didn't find them.
