Any ADA resources for Kinetis ?
1,845 次查看
NicolasP
I'd like to replace C with ADA when programming on Kinetis micro-controllers.
Any pointers to resources helping use ADA on Kinetis ?
Note : I already know Adacore GIT repositories managing GNAT for ARM devices.
Nicolas
1,784 次查看
Sabina_Bruce
Hello Nicolas,
Hope you are doing well.
Unfortunately, we do not have a guide to port code from C to ADA. All of our examples are implemented using C.
I recommend to check the documentation that you have mentioned and Adacore support system.
Hope it helps!
Sabina
1,785 次查看
Sabina_Bruce
Hello Nicolas,
Hope it helps!
Sabina
1,784 次查看
NicolasP
Hello Sabina,
Thanks for your answer.
I hoped you tell me another story :smileywink:
Never mind .
Nicolas
