AN14112 on KW45 where to find the proper example
442 次查看
ebadia
Taking a look at the AN14112 "Car Connectivity Consortium (CCC) Digital Key R3 – Bluetooth LE Vehicle Keyless Access System", in the point number 6, explains how to setup multiple anchors by modifing the NUM_ANCHORS, ANCHOR_INDEX, SE_FEATURE_SUPORT defines on the app_preinclude.h file.
But when I download the SDK (i have downloaded various versions of the EVK and non EVK), I can find the examples "digital_key_car_anchor" and "digital_key_device" (also the channel sounding examples on the latest SDK), but in their app_preinclude.h file there are none of those defines explained in the step 6 of the AN14112.
Could you please provide the example or indicate where can I find them?
KW45B41Z-EVK KW45
Thank you in advance,
1 回复
405 次查看
luis_maravilla
Hello
Hope you are doing well. Sorry for the inconvenience this might cause you but the information of this example the information it's not public.
Could you please contact one of our distributors available in the Distributor Network|NXP to help you with your request? Or you can contact the person who helped you getting this device.
I apologize for the inconveniences this might cause you and you project.
Best Regards
Luis
