I try to use the watchdog in the SDK1.3 for KL36.
I find that the watchdog API in the SDK1.3 does not suppot KL36.
Can you give me an example about it?
Hi Robin,
KL36 can refer to the KL46 sample code.
So you can use the KL46 watchdog (COP) code.
Besides, your sdk1.3.0 is old now, we suggest you use the new KSDK2.0, you can download the code from this link:
Welcome to Kinetis Expert | Kinetis Expert
Click build an SDK, then choose your KL36 chip, generate the KSDK2.0 code.
Wish it helps you!
If you still have question, please contact me!
Kerry
