16bit characters in IAR
541 次查看
ryanlush
I have some code written with Code Warrior that uses 16bit characters like so
char* str L"some string"
My understanding is that the L tells the compiler to treat the string as wide_t type characters. Trouble is in IAR the wide_t is 32bits so my string has 32bit characters. Is it possible to create a string in IAR with 16bit characters?
0 回复数
