我想找MK60DX256ZVLL10这个芯片最新的头文件,请问可以在哪里找到?谢了啦~
朱葛峻
Robin_Shen
I can see the newest MK60DZ10 in my CodeWarrior10.5.
It can be found in the folder show below:
E:\Program Files\Freescale\CW MCU v10.5\MCU\lib\wizard_data\ARM\DataBase\derivatives
In this MK60DZ10.h ,it shows the last change "rev. 1.6 (2013-04-05)"
**     Processors:          MK60DN512ZVLL10
**                          MK60DX256ZVLL10
**                          MK60DN256ZVLL10
**                          MK60DN512ZVLQ10
**                          MK60DN256ZVLQ10
**                          MK60DX256ZVLQ10
**                          MK60DN512ZVMC10
**                          MK60DN256ZVMC10
**                          MK60DX256ZVMC10
**                          MK60DN512ZVMD10
**                          MK60DX256ZVMD10
**                          MK60DN256ZVMD10
**     Compilers:           ARM Compiler
**                          Freescale C/C++ for Embedded ARM
**                          GNU C Compiler
**                          IAR ANSI C/C++ Compiler for ARM
**     Reference manual:    K60P144M100SF2RM, Rev. 5, 8 May 2011
**     Version:             rev. 1.6, 2013-04-05
**     Abstract:
**         This header file implements peripheral memory map for MK60DZ10
**         processor.
**     Copyright: 1997 - 2013 Freescale, Inc. All Rights Reserved.
**     http:                 www.freescale.com
**     mail:                 support@freescale.com
**     Revisions:
**     - rev. 1.0 (2011-03-30)
**         Initial version.
**         Changes with respect to the previous MK10NxxVMD100 header file:
**         RTC - CCR register removed. Replaced by IER register.
**         CRC - added CTRLHU register for 8-bit access to the CTRL register.
**         FB - bit FB_CSCR_EXALE renamed to FB_CSCR_EXTS.
**         SIM- bit group FSIZE in SIM_FCFG1 split into groups PFSIZE and NVMSIZE.
**         Added registers for core modules - CoreDebug, DWT, ETB, ETF, ETM, FPB, ITM, TPIU.
**     - rev. 1.1 (2011-06-15)
**         Registers updated according to the new reference manual revision - Rev. 5, 8 May 2011
**         I2S  - bit SSIEN in I2S_CR register renamed to I2SEN.
**         SDHC - bit VOLTSEL in SDHC_VENDOR register removed.
**         TSI - registers TSI_CNTR1 to TSI_CNTR15, bit group CNTN renamed to CTN1, bit group CNTN1 renamed to CTN.
**     - rev. 1.2 (2011-06-29)
**         Order of declarations changed.
**     - rev. 1.3 (2011-11-10)
**         Support of ARM Keil compiler added.
**     - rev. 1.4 (2012-01-10)
**         Registers updated according to the new reference manual revision - Rev. 6, 6 Nov 2011
**         ADC - PGALPb bit group added.
**         PDB - Register PO0EN renamed to POEN
**         SDHC - WRBRSTLEN bit group added
**         SIM - Bit DSPI0 in SCGC6 register renamed to SPI0.
**     - rev. 1.5 (2012-04-13)
**         Added new #define symbol MCU_MEM_MAP_VERSION_MINOR.
**         Added new #define symbols <peripheralType>_BASE_PTRS.
**     - rev. 1.6 (2013-04-05)
**         Changed start of doxygen comment.
Robin_Shen
**                          MK60DX256ZVLL10
**                          MK60DN256ZVLL10
**                          MK60DN512ZVLQ10
**                          MK60DN256ZVLQ10
**                          MK60DX256ZVLQ10
**                          MK60DN512ZVMC10
**                          MK60DN256ZVMC10
**                          MK60DX256ZVMC10
**                          MK60DN512ZVMD10
**                          MK60DX256ZVMD10
**                          MK60DN256ZVMD10
**                          GNU C Compiler
**     Abstract:
**         processor.
**     Revisions:
**         Initial version.
朱葛峻
Robin_Shen,您好。
          谢了啦,您给了我很大的帮助!我在我的IAR和CW(5.1)里面没有找到相应的文件夹和文件,不过,我现在正在下载CodeWarrior(10.5),应该能找到了。
          另外,希望您能原谅我用我的母语给您回复而带来的不便,因为我觉得要是我用英文的话,您阅读起来会更不方便的。总之,万分感谢!
               朱葛峻
Robin_Shen
Hi 葛峻
  You are welcome!
  If you describe your question in English , more people who are in our community can know your question and then help you.
  Thank you!
Best Regards
Robin
朱葛峻
Hi Robin,
     Thank you for your indication!
     I will try my best to sharpen my English skill and use it.
     P.S.     The reason I don't use English is that my English skill is so bad and I don't pass CET4. Please forgive me.
Sincerely yours,
朱葛峻
Robin_Shen
Hi 葛峻 ,
You can search "MK60DZ10" as the key words in your compiler folder.
I can find it in my IAR\Keil MDK\CodeWarrior compiler folder.
Hope that help
Best Regards
Binbin
