I can see the newest MK60DZ10 in my CodeWarrior10.5.
It can be found in the folder show below:
E:\Program Files\Freescale\CW MCU v10.5\MCU\lib\wizard_data\ARM\DataBase\derivatives
In this MK60DZ10.h ,it shows the last change "rev. 1.6 (2013-04-05)"
** Processors: MK60DN512ZVLL10
** MK60DX256ZVLL10
** MK60DN256ZVLL10
** MK60DN512ZVLQ10
** MK60DN256ZVLQ10
** MK60DX256ZVLQ10
** MK60DN512ZVMC10
** MK60DN256ZVMC10
** MK60DX256ZVMC10
** MK60DN512ZVMD10
** MK60DX256ZVMD10
** MK60DN256ZVMD10
** Compilers: ARM Compiler
** Freescale C/C++ for Embedded ARM
** GNU C Compiler
** IAR ANSI C/C++ Compiler for ARM
** Reference manual: K60P144M100SF2RM, Rev. 5, 8 May 2011
** Version: rev. 1.6, 2013-04-05
** Abstract:
** This header file implements peripheral memory map for MK60DZ10
** processor.
** Copyright: 1997 - 2013 Freescale, Inc. All Rights Reserved.
** http: www.freescale.com
** mail: support@freescale.com
** Revisions:
** - rev. 1.0 (2011-03-30)
** Initial version.
** Changes with respect to the previous MK10NxxVMD100 header file:
** RTC - CCR register removed. Replaced by IER register.
** CRC - added CTRLHU register for 8-bit access to the CTRL register.
** FB - bit FB_CSCR_EXALE renamed to FB_CSCR_EXTS.
** SIM- bit group FSIZE in SIM_FCFG1 split into groups PFSIZE and NVMSIZE.
** Added registers for core modules - CoreDebug, DWT, ETB, ETF, ETM, FPB, ITM, TPIU.
** - rev. 1.1 (2011-06-15)
** Registers updated according to the new reference manual revision - Rev. 5, 8 May 2011
** I2S - bit SSIEN in I2S_CR register renamed to I2SEN.
** SDHC - bit VOLTSEL in SDHC_VENDOR register removed.
** TSI - registers TSI_CNTR1 to TSI_CNTR15, bit group CNTN renamed to CTN1, bit group CNTN1 renamed to CTN.
** - rev. 1.2 (2011-06-29)
** Order of declarations changed.
** - rev. 1.3 (2011-11-10)
** Support of ARM Keil compiler added.
** - rev. 1.4 (2012-01-10)
** Registers updated according to the new reference manual revision - Rev. 6, 6 Nov 2011
** ADC - PGALPb bit group added.
** PDB - Register PO0EN renamed to POEN
** SDHC - WRBRSTLEN bit group added
** SIM - Bit DSPI0 in SCGC6 register renamed to SPI0.
** - rev. 1.5 (2012-04-13)
** Added new #define symbol MCU_MEM_MAP_VERSION_MINOR.
** Added new #define symbols <peripheralType>_BASE_PTRS.
** - rev. 1.6 (2013-04-05)
** Changed start of doxygen comment.
** MK60DX256ZVLL10
** MK60DN256ZVLL10
** MK60DN512ZVLQ10
** MK60DN256ZVLQ10
** MK60DX256ZVLQ10
** MK60DN512ZVMC10
** MK60DN256ZVMC10
** MK60DX256ZVMC10
** MK60DN512ZVMD10
** MK60DX256ZVMD10
** MK60DN256ZVMD10
** GNU C Compiler
** Abstract:
** processor.
** Revisions:
** Initial version.
Robin_Shen,您好。
谢了啦,您给了我很大的帮助!我在我的IAR和CW(5.1)里面没有找到相应的文件夹和文件,不过,我现在正在下载CodeWarrior(10.5),应该能找到了。
另外,希望您能原谅我用我的母语给您回复而带来的不便,因为我觉得要是我用英文的话,您阅读起来会更不方便的。总之,万分感谢!
朱葛峻
Hi 葛峻
You are welcome!
If you describe your question in English , more people who are in our community can know your question and then help you.
Thank you!
Best Regards
Robin
Hi Robin,
Thank you for your indication!
I will try my best to sharpen my English skill and use it.
P.S. The reason I don't use English is that my English skill is so bad and I don't pass CET4. Please forgive me.
Sincerely yours,
朱葛峻
Hi 葛峻 ,
You can search "MK60DZ10" as the key words in your compiler folder.
I can find it in my IAR\Keil MDK\CodeWarrior compiler folder.
Hope that help
Best Regards
Binbin
