Hi there,
I have two projects based on TWR-K21F120M. One is based on bare metal; the other one is based on PE.
When I tried to transplant some codes from each other, I saw compile errors. Then I compared the two MK21F12.h. They are so different. PE head file is 14415 lines. while the bare metal is 8287 lines. But when I compares the topline comments, they had the same version at the same date.
I just wonder what is the purpose to let KDS generate two different head files for one mcu? I can copy one over the other, but I am just so curious.
Thanks!
Haizhou
PE
** Compilers: ARM Compiler
** Freescale C/C++ for Embedded ARM
** GNU C Compiler
** IAR ANSI C/C++ Compiler for ARM
** Reference manual: K21P144M100SF5RM, Rev.2, Apr 2013
** Version: rev. 1.7, 2014-02-18
** Abstract:
** This header file implements peripheral memory map for MK21F12
** processor.
** Copyright: 1997 - 2014 Freescale, Inc. All Rights Reserved.
** http: www.freescale.com
** mail: support@freescale.com
** Revisions:
** - rev. 1.0 (2012-11-12)
** Initial version.
** - rev. 1.1 (2012-12-04)
** Update according to reference manual rev.1
** - rev. 1.2 (2013-01-21)
** Registers related to security features removed.
** - rev. 1.3 (2013-04-05)
** Changed start of doxygen comment.
** - rev. 1.4 (2013-04-23)
** System timer registers added.
** - rev. 1.5 (2013-05-16)
** Update according to reference manual rev.2
** - rev. 1.6 (2013-10-29)
** Definition of BITBAND macros updated to support peripherals with 32-bit acces disabled.
** - rev. 1.7 (2014-02-18)
** UART0 module - LON registers removed.
* @file MK21F12.h
* @version 1.7
* @date 2014-02-18
* @brief Peripheral memory map for MK21F12
* This header file implements peripheral memory map for MK21F12 processor.
bare metal
** GNU C Compiler
** GNU C Compiler - CodeSourcery Sourcery G++
** Abstract:
** CMSIS Peripheral Access Layer for MK21F12
** Revisions:
** Initial version.
** - rev. 1.3 (2013-03-11)
** System initialization updated to add 120MHz clock option.
** - rev. 1.4 (2013-04-05)
** The declaration of clock configurations has been moved to separate header file system_xxxx.h
** Startup file for gcc has been updated according to CMSIS 3.2.
** Access restriction of some registers fixed.
* @file MK21F12.h
* @version 1.7
* @date 2014-02-18
* @brief CMSIS Peripheral Access Layer for MK21F12
