Dear All,
I have a Project been created by cw10.6. Now,I want to use KDS1.1.0 to open and build it. but I'm failed.when I build my project,an error is comes out.
How to build my project in KDS1.1.0?
my project is in attachment.
bye
Original Attachment has been moved to: kl05_test.rar
解決済! 解決策の投稿を見る。
CodeWarrior and Kinetis Design studio are different tool chains (gcc) and different tool chain integration (the compiler/linker panels, etc).
So you cannot use CodeWarrior projects directly in Kinetis Design Studio and vice versa.
Have a look in C:\Freescale\KDS_2.0.0\doc\pdf\kds_porting_guide.pdf how to import and port a project.
That PDF is available on the Freescale KDS (http://www.freescale.com/kds) documentation page too:
http://cache.freescale.com/files/microcontrollers/doc/user_guide/KDS200PUG.pdf?fasp=1
But in general the best way is to create a new project in Kinetis Design Studio,then copy over all the sources.
If using Processor Expert project, then this article could be helpful for you: Export and Import Processor Expert Component Settings | MCU on Eclipse
I hope this helps,
Erich
I hope this helps,
Erich
OK,I see.
Thank you.
