how to code the accelerometer of kl25z by using KDS ide
2,955件の閲覧回数
amirche
Im new in designing the program for kl25z board by using kinetis design studio 3.0 IDE. Can you give me example or
simple sample code on how to set the accelerometer axis to RGB color of the LED?
3 返答(返信)
2,399件の閲覧回数
ZhangJennie
please check if this article can help you.
Using the Accelerometer on the FRDM-KL25 Board in KDS
Jennie Zhang
2,399件の閲覧回数
amirche
thank you so much for your support. It was so helpful!!!
2,399件の閲覧回数
ZhangJennie
Hi Jane,
You are welcome!
The previous account/input that i used for answering your question will be omitted. So I input the same again with my other account.
Please make the new input as helpful or correct if you think so.
thanks!
Jennie
