arm-none-eabi-gcc.exe has stopped working
5,211 次查看
niranjanbc
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
3,976 次查看
Hello niranjanbc,
I think maybe you put breakpoints to invalid palce, so try to delete all breakpoints from your breakpoints view.
And if it still can not work well ,Please give more information about your project to us .
Or you can send your project to me .
Alice
5 回复数
3,976 次查看
niranjanbc
I am getting error "arm-none-eabi-gcc.exe has stopped working "when I try to run Debugger
I see below message in console
"This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information"
3,976 次查看
BlackNight
There is a known problem with gdb if there are breakpoints/watchpoints or expressions to non-existing memory locations ("Failed to Debug with GDB: Breakpoints or Expressions on non-existing Locations | MCU on Eclipse "). Remove all breakpoints/etc before launching the debugger.
Another problem I have seen are virus scanners/firewalls which block the debugger: you might disable it to give it a try.
I hope this helps,
Erich
3,976 次查看
niranjanbc
thanks Erich, it fixed the problem
3,977 次查看
Hello niranjanbc,
Alice
3,976 次查看
niranjanbc
Thanks Alice it fixed the problem
