Working remote via SVN - KDS and KSDK/PE
Search instead for
tharonhall
I have been trying to checkout my project remotely from my laptop to work on my KDS project built as a KSDK/PE project and keep encountering various problems.
Can anyone point to any references about how to keep two different environments sharing SVN to work? I assume we might have the same problem with two different developers attempting to share the code.
I suspect one might have similar problems with any other CM tool, so my issues probably have more to do with tool paths and the like.
Thanks!
Tags (3)
Carlos_Mendoza
Hi Tharon,
I think that the following post created by our colleague Erich Styger might be helpful for you, it explains the usage of version control with Processor Expert projects:
http://mcuoneclipse.com/2013/03/29/version-control-with-processor-expert-projects/
Hope it helps!
Carlos Mendoza
Technical Support Engineer
Carlos_Mendoza
Hi Tharon,
Hope it helps!
Carlos Mendoza
tharonhall
Thanks Carlos, and especially to Erich! :smileyhappy:
