I have been trying to checkout my project remotely from my laptop to work on my KDS project built as a KSDK/PE project and keep encountering various problems.
Can anyone point to any references about how to keep two different environments sharing SVN to work? I assume we might have the same problem with two different developers attempting to share the code.
I suspect one might have similar problems with any other CM tool, so my issues probably have more to do with tool paths and the like.
Thanks!
Solved! Go to Solution.
Hi Tharon,
I think that the following post created by our colleague Erich Styger might be helpful for you, it explains the usage of version control with Processor Expert projects:
http://mcuoneclipse.com/2013/03/29/version-control-with-processor-expert-projects/
Hope it helps!
Carlos Mendoza
Technical Support Engineer
Hi Tharon,
Hope it helps!
Carlos Mendoza
Thanks Carlos, and especially to Erich! :smileyhappy:
