Why is build error
Why is build error
3,093 次查看
guohuoping
I is using Kinetis Design Studio, and build my project!
But It always push error message "recipe for target 'myproject.elf' failed "!
I am craze!
8 回复数
2,776 次查看
BlackNight
could you post the exact error message from the console view?
Otherwise, have you tried to do a clean (see https://mcuoneclipse.com/2012/03/12/no-rule-to-make-target/) with Project > Clean already?
I suspect your make files are pointing to the wrong files.
I hope this helps,
Erich
2,776 次查看
guohuoping
Hello!
Thank you for your answer!
The error message image is as bellow:
As your said, the makefile is really source of error push! But I did not still know how to shoot the problem!
2,776 次查看
BlackNight
Have you followed the advise above?
And that screenshot does not really help. What would help is the content or report in the Console view.
Erich
2,776 次查看
guohuoping
The console view is as follow.
I have checked and found that the IDE link step pushes error .
But every one file build step is ok.
The OS of my computer is Windows 10 and KDS version is v3.2.0.
2,776 次查看
Hello guo,
Does your project ported from old version KDS to KDS v3.2 ?
Please replace -nanolibc with --specs=nano.specs --specs=nosys.specs     to have a try .
Please have a look  these thread :
unrecognized command line option '-nanolibc'
Error1 unrecognized command line option '-nanolibc'
https://community.nxp.com/message/617086
Hope it helps
Alice
2,776 次查看
guohuoping
Thank You!
I use "KDS Upgrade Assistant..." help me to shoot problem! Now, My project is OK!
2,776 次查看
OK, Welcome !
Alice
2,776 次查看
guohuoping
Yes!
My project is just ported from old version KDS to KDS3.2.
I will try to do as you said!
Thank You very much!
