I am trying to create a Kinetis project with KDS, based on MK20DX256VLL7 (TWR-K20D72M).
I'd followed the steps described in the the KDS user Guide -> "Creating a Kinetis project".
When I reach the "Rapid Application Development" page, I am not able to select the SDK plugin.
If I select another chip (ex. MK60 or MK20DX256xxx10) it works good.
Is there a reason why the KSDK plugin could not be enabled with MK20DX256xxx7?
Regards.
Solved! Go to Solution.
Hello stephane,
I have checked KSDK1.3 and KSDK v2.0 , they don't support this chip now .
Sorry for the inconvenient to you . And I think you can use the Processor Expert to
development your project , it also easy to development .
Hope it helps
Alice
Hello stephane,
Hope it helps
Alice
