USBDM realtime debugging
6,139件の閲覧回数
gschelotto
Is it possible to enable real-time view of expressions while I debug using USBDM and KDS 3.0?
regards,
gaston
5,922件の閲覧回数
ZhangJennie
I didn't receive any information regarding this feature in the new version.
but as a suggestion, i suggest you create a SR as a feature requst to support@freescale.com
freescale support team may escalate it.
Zhang Jun
5 返答(返信)
5,912件の閲覧回数
ZhangJennie
hi,
please go to IDE menu "Window", "Show View", "Expressions" to open the expression window.
for more information. please see attached video.
can this help?
Zhang Jun
5,912件の閲覧回数
gschelotto
can this help?
Not really. I'd like to see how the expressions change in some auto-refresh mode (ie. every 100ms), during runtime debug.
regards,
gaston
5,912件の閲覧回数
ZhangJennie
Hi gaston,
With CodeWarrior I can watch varables while the target is running ( Live View for Variables and Memory | MCU on Eclipse ). This is a CodeWarrior specific extension of CDT, and not available in KDS.
CodeWarrior is using a proprietary debugger engine, while KDS is using gdb.
all of above are mentioned in professor Erich's blog:
Comparing CodeWarrior with Kinetis Design Studio | MCU on Eclipse
does this make sense for you?
Zhang Jun
5,912件の閲覧回数
gschelotto
Hi Zhang,
Okay, thank you for the clarification. This feature will be available in future KDS releases? I don't know if it's supported by gdb.
regards,
gaston
5,923件の閲覧回数
ZhangJennie
Zhang Jun
