Processor Expert configuration for twr-k24f120m
2,332 次查看
lingqian
Hi all,
I met a problem in finding corresponding TWR-K24F120M board configuration in Kinetis Design Studio.
I was using the Processor Expert in KDS to do all my coding for K64F and everything was fine. Recently, I bought another board TWR-K24F120M and wanted to transfer my previous code to this new board. However, I couldn't find any Processor Expert board Configuration for this board. The attachment is information of the KDS I am using now.
It seems that using KSDK may help me find the right board, but I prefer using PE to program my project. Is there anything I can do to solve this problem?
Ling
2,188 次查看
ZhangJennie
hi Ling,
please refer attached video for how to use processor expert with TWR-K24F120M board.
I use KDS3.0 with all updates installed.
New Kinetis Design Studio V3.0.0 available
can this help you?
Zhang Jun
2,188 次查看
lingqian
Hi Jun,
Thanks for your quick reply and the video, now I can find the TWR-K24F120M board. However, I have to rely on KSDK in order to configure this board. Since I didn't use KSDK before, I am really confusing about how to migrate my previous program to this new one.  For example, perviously, I used SPIMaster_LDD component to set up my SPI transmission function, but there is only a component in KSDK called fsl_dspi. Are they the same? Can I use the same configuration I did before to this component?
Thanks again.
Ling
2,188 次查看
ZhangJennie
hi Ling
Processor expert use another set of pe component, starting with fsl_xxx and Init_xxx.
SPIMaster_LDD component can not work for KSDK anymore.
you can check which pe component working for KSDK in this way:
can this help you?
Zhang Jun
