Porting application using older CMSIS to new KDS
931 次查看
piotrcerba
I have an older application running on KL43 board using such files:
common.h, core_cm0.h, drivers.h, pit.c, pit.h and many more.
After copying the "old" code to my current KDS 3.0 + SDK 1.2 project I am getting numerous conflicts and "No such file" errors.
As I see the whole CMSIS is different.
Is there any simple way to convert older code to a new one which is using eg. core_cm0plus.h instead of core_cm0.h?
标记 (4)
854 次查看
ZhangJennie
what's your old project developed with ? CW or KDS? what's the version? did you use any SDK or other RTOS with the old project? if yes, what's the version?
additionally, what the error message? please post its screenshot here. thanks!
Zhang Jun
