NEWLY INSTALLED KDS3.2 getting "No projects are found to import"
craigflanagan
Hello, I am new to the Kinetis mcus/development system. I have an FRDM-KL27Z that I would
like to run the demo apps on. I installed SDK 2.2.1 (I tried 1.3 as well) and KDS 3.2. I am
not able to get a demo project to load:
  FILE > IMPORT > GENERAL PROJECTS > EXISTING PROJECTS INTO WORKSPACE
  (also tried:  FILE > IMPORT > PROJECT OF PROJECTS > EXISTING PROJECTS)
and I try to point to project (see first attachment) and the project does not show up in
the lower PROJECTS box (see second attachment).
Any ideas? I have been playing with this for quite some time and no luck here. Thanks. Craig
Hello Craig,
Have you select the the KDS when you download SDK ?
Hope it helps
TIC
