KDS compile, not build
1,017 次查看
roymessinger
Contributor V
1. Is there any way I can compile the source file in KDS software without build? (saving time)
2. sometimes when I click 'cancel' the build in the KDS IDE, the software hangs. Any ideas how to solve it?
Thanks.
888 次查看
BlackNight
Hi Roy,
1. Yes, there is a way: Build and Clean Selected Files in Eclipse CDT | MCU on Eclipse .
2. Hard to say what is causing this. Are you using the default managed make files (by default)?
About saving time: make sure you have parallel build enabled (see Reducing Compile Time in Eclipse with Parallel Build | MCU on Eclipse ). Another tip is to disable build-before-debug (see Speeding up the Debug Launch in CodeWarrior | MCU on Eclipse )
I hope this helps,
Erich
888 次查看
roymessinger
Contributor V
Regarding problem 2 - yes.
I've read alot of complaints in stackoverflow.com regarding this issue in Eclipse, and KDS is using the Eclipse, but still - didn't find any solution.
