KDS IDE Beta_ Windows : Retrieving SDK Version Failed
2,431 次查看
navyareddy
DescriptionResourcePathLocationType
ERROR: Retrieving SDK version failed, please check SDK source files consistency (C:\Freescale\SDK_1.0.0-Beta\doc\Kinetis_SDK_Version.xml not found or corrupted).kCpuProcessor Expert Problem
This error is popping up whenever i'm trying to create a new project using SDK and Processor Expert for rapid application development. How can I overcome this problem and successfully generate a code by configuring  elements.
Is IAR and GCC are the only IDE's currently supporting SDK Beta version?
Thank You in advance.
标记 (1)
2,249 次查看
BlackNight
Can you check your (Windows?) environement variables?
The should point to:
KSDK_PATH=C:\Freescale\KSDK_1.0.0-Beta
KSDK_PATH_1_0_0_BETA=C:\Freescale\KSDK_1.0.0-Beta
And you should check that you have
in
C:\Freescale\KSDK_1.0.0-Beta\doc
(I have mine attached).
do you have something different?
