KDS Debugger Settings
659 次查看
rabbitz
I am Code Warrior user, just satrt KDS shortly.
My target board is SWD debugging interface,  "MultiLink Universal RevC" is the debugger.
When I start debugging, it downloading firmware to the target, it comes  error message "Program file does not exist", but the .elf is existing,
Is there any tutoring document for KDS debugging settings?
Sam
571 次查看
DavidS
Hi Sam,
What target board?
I have seen where the Debug Configuration for the PEMicro debugger firmware defaults to USB Multilink and you need to change it to OpenSDA.
Once in awhile I have also not had the ELF file pointed to in the C/C++ Application: enter in the Main tab window.  Usually Search Project... will find it.  If not then Browse... to it will work.
David
