KDS 2.0 debugger disconnects on entry into LLS
1,433 次查看
eyaldoron
KDS 2.0 debugger disconnects on entry into LLS (KL15 processor). I'm using the ARM launchpad GNU tools. Is there a way to reconnect automatically, such as was the case for Codewarrior? Otherwise debugging LLS projects is very tricky.
1,336 次查看
DavidS
Hi Eyal,
In general the KDS does not allow debugger connections when entering low power modes.
If an application is running, there is process for connecting to it but again not when in the low power mode.
Attaching to a Running Target with Segger J-Link, GDB and Eclipse | MCU on Eclipse
David
1,336 次查看
eyaldoron
1,336 次查看
Carlos_Mendoza
Hi Eyal Doron,
I think there was an error while posting your reply and it is empty, could you please try again?
Carlos Mendoza
Technical Support Engineer
