I just tried creating a new test project with KDS version 1.1.1 and noticed that: #include - "fsl_device_registers.h" no longer is placed in main.c. I tried manually putting in but get an error saying, Not Found. Has something changed with this version or am I missing something. (I do not use Processor Expert).
John Baker
Solved! Go to Solution.
Hi John
"fsl_device_registers.h" is a SDK file , if you make sure the SDK install successfully, it in here(C:\Freescale\KSDK_1.0.0\platform\CMSIS\Include\device),
If your project is still have error, you can send us.
Hope it helps
Alice
Hi John
Hope it helps
Alice
Hi.
Have you checked the include path?
it works for me
#include "device/fsl_device_registers.h"
