Enable multiarch first:
dpkg --add-architecture i386
apt-get update
apt-get install ia32-libs
and probably some more i386 libs until it runs smooth. This is what I've collected so far on a Debian sid system:
root@oppa-hex-ssd:~# uname -r
3.17-2.towo-siduction-amd64
root@oppa-hex-ssd:~# dpkg -l | grep :i386
ii gcc-4.8-base:i386 4.8.3-13 i386 GCC, the GNU Compiler Collection (base package)
ii gcc-4.9-base:i386 4.9.2-1 i386 GCC, the GNU Compiler Collection (base package)
ii glib-networking:i386 2.42.0-2 i386 network-related giomodules for GLib
ii gtk2-engines-murrine:i386 0.98.1.1-5 i386 cairo-based gtk+-2.0 theme engine
ii libacl1:i386 2.2.52-2 i386 Access control list shared library
ii libasound2:i386 1.0.28-1 i386 shared library for ALSA applications
ii libatk-bridge2.0-0:i386 2.14.0-2 i386 AT-SPI 2 toolkit bridge - shared library
ii libatk1.0-0:i386 2.14.0-1 i386 ATK accessibility toolkit
ii libatspi2.0-0:i386 2.14.0-1 i386 Assistive Technology Service Provider Interface - shared library
ii libattr1:i386 1:2.4.47-2 i386 Extended attribute shared library
ii libavahi-client3:i386 0.6.31-4 i386 Avahi client library
ii libavahi-common-data:i386 0.6.31-4 i386 Avahi common data files
ii libavahi-common3:i386 0.6.31-4 i386 Avahi common library
ii libavahi-glib1:i386 0.6.31-4 i386 Avahi GLib integration library
ii libbsd0:i386 0.7.0-2 i386 utility functions from BSD systems - shared library
ii libc6:i386 2.19-13 i386 GNU C Library: Shared libraries
ii libcairo-gobject2:i386 1.14.0-2.1 i386 Cairo 2D vector graphics library (GObject library)
ii libcairo2:i386 1.14.0-2.1 i386 Cairo 2D vector graphics library
ii libcanberra-gtk3-0:i386 0.30-2.1 i386 GTK+ 3.0 helper for playing widget event sounds with libcanberra
ii libcanberra-gtk3-module:i386 0.30-2.1 i386 translates GTK3 widgets signals to event sounds
ii libcanberra0:i386 0.30-2.1 i386 simple abstract interface for playing event sounds
ii libcolord2:i386 1.2.1-1+b1 i386 system service to manage device colour profiles -- runtime
ii libcomerr2:i386 1.42.12-1 i386 common error description library
ii libcups2:i386 1.7.5-7 i386 Common UNIX Printing System(tm) - Core library
ii libdatrie1:i386 0.2.8-1 i386 Double-array trie library
ii libdbus-1-3:i386 1.8.8-2 i386 simple interprocess messaging system (library)
ii libdbus-glib-1-2:i386 0.102-1 i386 simple interprocess messaging system (GLib-based shared library)
ii libdrm-nouveau2:i386 2.4.58-2 i386 Userspace interface to nouveau-specific kernel DRM services -- runtime
ii libdrm-radeon1:i386 2.4.58-2 i386 Userspace interface to radeon-specific kernel DRM services -- runtime
ii libdrm2:i386 2.4.58-2 i386 Userspace interface to kernel DRM services -- runtime
ii libedit2:i386 3.1-20140620-2 i386 BSD editline and history libraries
ii libegl1-mesa:i386 10.3.2-1 i386 free implementation of the EGL API -- runtime
ii libelf1:i386 0.159-4 i386 library to read and write ELF files
ii libexpat1:i386 2.1.0-6 i386 XML parsing C library - runtime library
ii libffi6:i386 3.1-2 i386 Foreign Function Interface library runtime
ii libfontconfig1:i386 2.11.0-6.1 i386 generic font configuration library - runtime
ii libfreetype6:i386 2.5.2-2 i386 FreeType 2 font engine, shared library files
ii libgbm1:i386 10.3.2-1 i386 generic buffer management API -- runtime
ii libgcc1:i386 1:4.9.2-1 i386 GCC support library
ii libgconf-2-4:i386 3.2.6-3 i386 GNOME configuration database system (shared libraries)
ii libgcrypt11:i386 1.5.4-3 i386 LGPL Crypto library - runtime library
ii libgdk-pixbuf2.0-0:i386 2.31.1-2+b1 i386 GDK Pixbuf library
ii libgl1-mesa-glx:i386 10.3.2-1 i386 free implementation of the OpenGL API -- GLX runtime
ii libglapi-mesa:i386 10.3.2-1 i386 free implementation of the GL API -- shared library
ii libglib2.0-0:i386 2.42.0-2 i386 GLib library of C routines
ii libglu1-mesa:i386 9.0.0-2 i386 Mesa OpenGL utility library (GLU)
ii libgmp10:i386 2:6.0.0+dfsg-6 i386 Multiprecision arithmetic library
ii libgnomevfs2-0:i386 1:2.24.4-6 i386 GNOME Virtual File System (runtime libraries)
ii libgnutls-deb0-28:i386 3.3.8-3 i386 GNU TLS library - main runtime library
ii libgnutls26:i386 2.12.23-17 i386 GNU TLS library - runtime library
ii libgnutls28:i386 3.2.15-1 i386 GNU TLS library - main runtime library
ii libgpg-error0:i386 1.17-2 i386 library for common error values and messages in GnuPG components
ii libgraphite2-3:i386 1.2.4-3 i386 Font rendering engine for Complex Scripts -- library
ii libgssapi-krb5-2:i386 1.12.1+dfsg-13 i386 MIT Kerberos runtime libraries - krb5 GSS-API Mechanism
ii libgtk-3-0:i386 3.14.4-2 i386 GTK+ graphical user interface library
ii libgtk2.0-0:i386 2.24.25-1 i386 GTK+ graphical user interface library
ii libharfbuzz0b:i386 0.9.35-2 i386 OpenType text shaping engine (shared library)
ii libhogweed2:i386 2.7.1-3 i386 low level cryptographic library (public-key cryptos)
ii libice6:i386 2:1.0.9-1 i386 X11 Inter-Client Exchange library
ii libidl0:i386 0.8.14-0.4 i386 library for parsing CORBA IDL files
ii libidn11:i386 1.29-1 i386 GNU Libidn library, implementation of IETF IDN specifications
ii libjasper1:i386 1.900.1-debian1-2.1+b1 i386 JasPer JPEG-2000 runtime library
ii libjbig0:i386 2.1-3.1 i386 JBIGkit libraries
ii libjpeg62-turbo:i386 1:1.3.1-10 i386 libjpeg-turbo JPEG runtime library
ii libjpeg8:i386 8d1-2 i386 Independent JPEG Group's JPEG runtime library
ii libjson-glib-1.0-0:i386 1.0.2-1 i386 GLib JSON manipulation library
ii libk5crypto3:i386 1.12.1+dfsg-13 i386 MIT Kerberos runtime libraries - Crypto Library
ii libkeyutils1:i386 1.5.9-5 i386 Linux Key Management Utilities (library)
ii libkrb5-3:i386 1.12.1+dfsg-13 i386 MIT Kerberos runtime libraries
ii libkrb5support0:i386 1.12.1+dfsg-13 i386 MIT Kerberos runtime libraries - Support library
ii liblcms2-2:i386 2.6-3+b2 i386 Little CMS 2 color management library
ii libllvm3.4:i386 1:3.4.2-13 i386 Modular compiler and toolchain technologies, runtime library
ii libllvm3.5:i386 1:3.5-6 i386 Modular compiler and toolchain technologies, runtime library
ii libltdl7:i386 2.4.2-1.11 i386 System independent dlopen wrapper for GNU libtool
ii liblzma5:i386 5.1.1alpha+20120614-2 i386 XZ-format compression library
ii libncurses5:i386 5.9+20140913-1 i386 shared libraries for terminal handling
ii libnettle4:i386 2.7.1-3 i386 low level cryptographic library (symmetric and one-way cryptos)
ii libnspr4:i386 2:4.10.7-1 i386 NetScape Portable Runtime Library
ii libnss3:i386 2:3.17.2-1 i386 Network Security Service libraries
ii libnss3-1d:i386 2:3.17.2-1 i386 Network Security Service libraries - transitional package
ii libogg0:i386 1.3.2-1 i386 Ogg bitstream library
ii liborbit-2-0:i386 1:2.14.19-0.3 i386 high-performance CORBA implementation - common libraries
ii liborbit2:i386 1:2.14.19-0.3 i386 high-performance CORBA implementation - extra libraries
ii libp11-kit0:i386 0.20.7-1 i386 Library for loading and coordinating access to PKCS#11 modules - runtime
ii libpango-1.0-0:i386 1.36.8-2 i386 Layout and rendering of internationalized text
ii libpango1.0-0:i386 1.36.8-2 i386 Layout and rendering of internationalized text
ii libpangocairo-1.0-0:i386 1.36.8-2 i386 Layout and rendering of internationalized text
ii libpangoft2-1.0-0:i386 1.36.8-2 i386 Layout and rendering of internationalized text
ii libpangox-1.0-0:i386 0.0.2-5 i386 pango library X backend
ii libpangoxft-1.0-0:i386 1.36.8-2 i386 Layout and rendering of internationalized text
ii libpcre3:i386 1:8.35-3.1 i386 Perl 5 Compatible Regular Expression Library - runtime files
ii libpixman-1-0:i386 0.32.6-3 i386 pixel-manipulation library for X and cairo
ii libpng12-0:i386 1.2.50-2 i386 PNG library - runtime
ii libproxy1:i386 0.4.11-4 i386 automatic proxy configuration management library (shared)
ii librest-0.7-0:i386 0.7.92-2 i386 REST service access library
ii libselinux1:i386 2.3-2 i386 SELinux runtime shared libraries
ii libsm6:i386 2:1.2.2-1 i386 X11 Session Management library
ii libsoup-gnome2.4-1:i386 2.48.0-1 i386 HTTP library implementation in C -- GNOME support library
ii libsoup2.4-1:i386 2.48.0-1 i386 HTTP library implementation in C -- Shared library
ii libsqlite3-0:i386 3.8.7.1-1 i386 SQLite 3 shared library
ii libstdc++6:i386 4.9.2-1 i386 GNU Standard C++ Library v3
ii libtasn1-6:i386 4.2-2 i386 Manage ASN.1 structures (runtime)
ii libtdb1:i386 1.3.1-1 i386 Trivial Database - shared library
ii libthai0:i386 0.1.21-1 i386 Thai language support library
ii libtiff5:i386 4.0.3-10+b2 i386 Tag Image File Format (TIFF) library
ii libtinfo5:i386 5.9+20140913-1 i386 shared low-level terminfo library for terminal handling
ii libudev1:i386 215-5+b1 i386 libudev shared library
ii libusb-0.1-4:i386 2:0.1.12-25 i386 userspace USB programming library
ii libusb-1.0-0:i386 2:1.0.19-1 i386 userspace USB programming library
ii libusb-1.0-0-dbg:i386 2:1.0.19-1 i386 userspace USB programming library development files
ii libusb-1.0-0-dev:i386 2:1.0.19-1 i386 userspace USB programming library development files
ii libuuid1:i386 2.25.2-2 i386 Universally Unique ID library
ii libvorbis0a:i386 1.3.4-2 i386 decoder library for Vorbis General Audio Compression Codec
ii libvorbisfile3:i386 1.3.4-2 i386 high-level API for Vorbis General Audio Compression Codec
ii libwayland-client0:i386 1.6.0-2 i386 wayland compositor infrastructure - client library
ii libwayland-cursor0:i386 1.6.0-2 i386 wayland compositor infrastructure - cursor library
ii libwayland-server0:i386 1.6.0-2 i386 wayland compositor infrastructure - server library
ii libx11-6:i386 2:1.6.2-3 i386 X11 client-side library
ii libx11-xcb1:i386 2:1.6.2-3 i386 Xlib/XCB interface library
ii libxau6:i386 1:1.0.8-1 i386 X11 authorisation library
ii libxcb-dri2-0:i386 1.10-3 i386 X C Binding, dri2 extension
ii libxcb-dri3-0:i386 1.10-3 i386 X C Binding, dri3 extension
ii libxcb-glx0:i386 1.10-3 i386 X C Binding, glx extension
ii libxcb-present0:i386 1.10-3 i386 X C Binding, present extension
ii libxcb-render0:i386 1.10-3 i386 X C Binding, render extension
ii libxcb-shape0:i386 1.10-3 i386 X C Binding, shape extension
ii libxcb-shm0:i386 1.10-3 i386 X C Binding, shm extension
ii libxcb-sync1:i386 1.10-3 i386 X C Binding, sync extension
ii libxcb-xfixes0:i386 1.10-3 i386 X C Binding, xfixes extension
ii libxcb1:i386 1.10-3 i386 X C Binding
ii libxcomposite1:i386 1:0.4.4-1 i386 X11 Composite extension library
ii libxcursor1:i386 1:1.1.14-1 i386 X cursor management library
ii libxdamage1:i386 1:1.1.4-2 i386 X11 damaged region extension library
ii libxdmcp6:i386 1:1.1.1-1 i386 X11 Display Manager Control Protocol library
ii libxext6:i386 2:1.3.3-1 i386 X11 miscellaneous extension library
ii libxfixes3:i386 1:5.0.1-2 i386 X11 miscellaneous 'fixes' extension library
ii libxft2:i386 2.3.2-1 i386 FreeType-based font drawing library for X
ii libxi6:i386 2:1.7.4-1 i386 X11 Input extension library
ii libxinerama1:i386 2:1.1.3-1 i386 X11 Xinerama extension library
ii libxkbcommon0:i386 0.4.3-2 i386 library interface to the XKB compiler - shared library
ii libxml2:i386 2.9.2+dfsg1-1 i386 GNOME XML library
ii libxrandr2:i386 2:1.4.2-1 i386 X11 RandR extension library
ii libxrender1:i386 1:0.9.8-1 i386 X Rendering Extension client library
ii libxshmfence1:i386 1.1-4 i386 X shared memory fences - shared library
ii libxt6:i386 1:1.1.4-1 i386 X11 toolkit intrinsics library
ii libxtst6:i386 2:1.2.2-1 i386 X11 Testing -- Record extension library
ii libxxf86vm1:i386 1:1.1.3-1 i386 X11 XFree86 video mode extension library
ii zlib1g:i386 1:1.2.8.dfsg-2 i386 compression library - runtime
