I installed Kinetis Design Studio v3.2.0. I am trying to work on freescale FRDM KL28z board. I am unable to view the EmbSys Register view since there is no MKL28z chip in the configuration of the same. Thank you for the help
ソリューションへジャンプ
1,808件の閲覧回数
harikrishnanp
MKL28z is not showing on the EmbSys configuration of the chip.
1,647件の閲覧回数
ZhangJennie
I think you can refer this document to add MKL28z to EmbSymRegView.
https://community.nxp.com/docs/DOC-334307
If you have any specific problem with it, please just let me know.
Jennie Zhang
3 返答(返信)
1,647件の閲覧回数
harikrishnanp
Thank you for your quick help. I was able to add the device into the Embsys register view configuration. But still I am not able to see any changes in these registers when working with the board.@ZhangJennie
1,644件の閲覧回数
ZhangJennie
I followed the document, I can add the device to Embsys successfully.
I suggest you create a new workspace to test it again. and make sure your xml file is correct. I enclose it for your referral.
Jennie Zhang
1,648件の閲覧回数
ZhangJennie
Jennie Zhang
