How to view global variables under KDS3.20?
2,070件の閲覧回数
junwang1
5 返答(返信)
1,833件の閲覧回数
781812756
Hi, Alice
Thanks for your help!
Jimmy
1,833件の閲覧回数
781812756
I tried, but fail. How to solve this bug? which  is the simplest solution?
1,833件の閲覧回数
Hello Jimmy,
If you want check the global variable , please use the "Expression" view:
Window -> show view -> Expressions
Hope it helps
Alice
1,833件の閲覧回数
jamiepacker
This is a known bug in Eclipse (Bug 219040 – [variables][cdi] Variables view should show globals (or should it?) )
The workaround is to add the global variable to the Expressions view.
1,833件の閲覧回数
junwang1
Add global variables is disable under KDS3.20, why?
