How to set the advanced view tab in KDS3.0 for more infomation on PE Component lib
1,121件の閲覧回数
ajaykumarnavalg
hi
i am the changing PE component view from Basic to Advanced view by using the Advanced button. but i not enable to see the more information related to the component,
EX: if the eDMA component is selected. in the basic view i am unable to see the high level configuration information, if i change the view to Advanced view, then i should be enable to see the register level configuration information like setting the minor/major loop of the eDMA component,
please guide on this
タグ(2)
1,045件の閲覧回数
Hello ajay,
Please select the component of "Init_eDMA":
then you can see the configure information about the dma registers , for example the minor/major loop of the eDMA component .
Hope it helps
Alice
