Hello I simply want to use kinetis design studio with ksdk 1.2.0 but when I start a new project and want to find the FRDM-KL03z processor it isnt located there ? Is there any way to add my board into the supported device list in kinetis design studio ?
解決済! 解決策の投稿を見る。
Hello
Attached here with step by step images to create new project for FRDM-KL03z. please go through it.
NOTE: Hope you are using kinetis design studeo 3.1.0 and SDk 1.3.0.
Let me know if any....
MARK it as correct if this post answers your question.
Harsh
Hello
Harsh
Hi Volkan,
I am assuming you are using KDS3.0 and have installed KSDK_1.2.
Now please read: C:\Freescale\KSDK_1.2.0\doc\Getting Started with Kinetis SDK (KSDK) v.1.2.pdf .
Start with chapter 5 Run a demo using Kinetis Design Studio IDE.
It will show you how to associate the KSDK1.2 to KDS. This will allow KDS to know what devices/MCUs are supported with KSDK1.2.
When you create a new project, then KL03Z will be available and a new project will be instantiate with or without PE (Processor Expert) support (your decision).
Hope this helps.
David
