How to configure MCU enter Vll0 and wake by lptmr and port in KDS 3
thoomanwang
I am using MKL02 and developemnt toos is KDS
How to configure MCU enter Vll0 and wake by lptmr and port in KDS 3(KSDK 1.3)?
i am not found componment in componment library.
Hello Thooman,
There is a demo about  power manager under the KSDK1.3 :
KSDK_1.3.0\examples\frdmkl02z\demo_apps\power_manager_hal_demo
you can refer to it .
And in the KSDK PE component lib , there is a component "fsl_power_manager".
Hope it helps
Alice
thoomanwang
Thanks Alice_Yang
bobpaddock
Senior Contributor III
If vll0 = VLLS0 , LPTMR is stopped in VLLS0 and it is VLLS3 that needs to be used (Not all parts have VLLS2 check your data sheet for your part).
