I'm using the Pre-build steps and Post-build-steps feature of KDS 3.2. (Yes, I will switch to MCUXpresso as soon as I can figure out how to create a Bootloader Configuration Area in MCUXpresso.)
I have observed that the build process proceeds asynchronously: it doesn't wait for the pre-build script to complete before moving on. In my case, that causes an error, since the pre-build step creates a file that is required by other parts of the build.
Question: is there a way to make the pre-build step synchronous, that is, cause the build process to wait until the pre-build step completes?
To demonstrate the problem, here are two simple scripts, pre-build.sh and post-build.sh. pre-build creates a file, post-build prints out its size. Note that pre-build.sh imposes an artificial ten second delay to expose the problem.
file: pre-build.sh
#/bin/sh /bin/echo === pre start === rm -f woof.txt sleep 10 /bin/echo woof > woof.txt /bin/echo -n pre `date "+%H:%M:%S"` " " ls -l woof.txt /bin/echo === pre end ===
file: post-build.sh
#/bin/sh /bin/echo === post start === /bin/echo -n post `date "+%H:%M:%S"` " " ls -l woof.txt /bin/echo === post end ===
The result of running:
**** Incremental Build of configuration Debug for project myproj **** make -j7 pre-build main-build ./pre-script.sh Building file: ../source/probe.c === pre start === Invoking: Cross ARM C Compiler arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -O0 ... Finished building: ../source/probe.c Building target: myproj.elf Invoking: Cross ARM C++ Linker arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -O0 ... Finished building target: myproj.elf make --no-print-directory post-build ./post-script.sh === post start === ls: woof.txt: No such file or directory post 18:16:45 === post end === Invoking: Cross ARM GNU Create Flash Image arm-none-eabi-objcopy -O srec "myproj.elf" "myproj.srec" Invoking: Cross ARM GNU Print Size arm-none-eabi-size --format=berkeley "myproj.elf" text data bss dec hex filename 35124 1516 3216 39856 9bb0 myproj.elf Finished building: myproj.siz Finished building: myproj.srec pre 18:16:55 -rw-r--r-- 1 r staff 5 Sep 18 18:16 woof.txt === pre end === 18:16:55 Build Finished (took 10s.162ms)
Note that pre-build created the file long after post-build (unsuccessfully) tried to access it.
已解决! 转到解答。
Suspecting that this is a generic problem with Eclipse and not a problem specific to KDS, I found "Bug 501065 - Pre-build steps not terminated before build is started with enabled parallel build op... in the Eclipse bug database.
And good news: In Project => Properties => C/C++ Build => [Behavior], unchecking the "Enable Parallel Build" box forces the pre-build step to complete before moving on to the rest of the build.
Solved.
A perhaps better workaround, that will let you keep the parallel builds, can be found here:
Parallel build using generated makefile doesn't manage dependencies
Until CDT 9.3 is out, the following workaround can be used:
1. Add a makefile.init in the project root with the following content:
allwithpre :
$(MAKE) --no-print-directory pre-build
$(MAKE) --no-print-directory main-build
2. Remove the pre-build task from the configuration
3. In the project settings, C/C++ Build -> Behavior -> Workbench Build Behavior, Change "all" to "allwithpre"
Solved.
