How to Enable Internal Pullup Resistors in KDS
nicksaulnier
Hello everyone!
I am using the KDS to program a FRDM-KL25Z board. Table 10.2 of the KL25Z Reference Manual indicates that all GPIO pins can be configured so that Pull Enable = 1 (i.e., an internal pullup resistor is enabled on the corresponding pin). How do I set Pull Enable on the KL25Z in the KDS?
Thank you,
Nick
BlackNight
nicksaulnier
The necessary Pin Control Register n (PORTx_PCRn) to enable pullup resistors (11.5.1 in KL25Z Reference Manual) does not seem to be accessible through the Processor Expert configuration registers view.
BlackNight
nicksaulnier
The Processor Expert PinSettings component which will set these bits for other MCUs does not seem to be supported for the KL25Z.
