How can I automate building KDS projects on a server through a script rather than on my machine using the IDE?
tamermash
We need to automate our builds on a server to build our KDS projects; however, there's no make file of some sort to build using command line. How can I make that work?
BlackNight
KDS creates and uses normal make files. So you can use them from a normal make executable without the IDE.
Erich
Stano
Hello Tamer,
you can use this link: Welcome to Kinetis Expert | Kinetis Expert
and download the Kinetis SDK Project Generator tool. This tool will generate project for you.
I think it will help for you.
Stano.
tamermash
Thank you Stano but I'm not using the SDK.
