Help with component Ldd_PWM  or debugging in KDS
2,283 次查看
artembilik
I have problems with components in LDD_PWM KDS2.0.0 for K60 120. Do as shown in the example (1) ldd_pwm. But when you debug breakpoint occurs opposite the initialization function PWM. Debugging with P & E multilink universal.
sorry for my english, it's Google translator:)
2,143 次查看
BlackNight
6 回复数
2,143 次查看
artembilik
No source available for "main() at D:\workspace.kds\MyPWMAbstract\Sources\main.c:56 0x4ce"
2,143 次查看
BlackNight
without further information I'm guessing that
a) you don't debug the right application binary
b) you have not rebuild the application after source modification
Erich
2,143 次查看
artembilik
Thanks for the reply, Eric.
Может быть поможет эта информация...
Marker constantly stops
PE_ISR (Cpu_ivINT_Hard_Fault)
   / * This code can be changed using the CPU component property "Build Options / Unhandled int code" * /
   this!!! -> PE_DEBUGHALT ();
My program has ceased normal Debug after I broke up the CPU frequency up to 120 MHz
But the content of the report file debugger:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<launchConfiguration type="com.pemicro.debug.gdbjtag.pne.launchConfigurationType">
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.PE.DEVICE_NAME" value="K60FX512"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.PE.GDB_IP" value="127.0.0.1"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.PE.GDB_OPTIONS" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.PE.GDB_PORT" value="7224"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.PE.HARDWARE_INTERFACE" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.PE.LAST_ATTRIBUTE_HEADER" value="com.pemicro.debug.gdbjtag.pne.ml."/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.PE.USE_EXTERNAL_SERVER" value="true"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_eth.ALWAYS_ERASE" value="false"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_eth.CYCLONE_IP" value=""/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_eth.DO_RESET_DELAY" value="false"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_eth.INTERFACE_PORT" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_eth.INTERFACE_PORT_STRING" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_eth.NETWORK_CARD_IP" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_eth.POWER_DOWN_DELAY" value="250"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_eth.POWER_OFF" value="false"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_eth.POWER_UP_DELAY" value="250"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_eth.PROVIDE_POWER" value="false"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_eth.REGULATOR_VOLTAGE" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_eth.RESET_DELAY" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_eth.SHIFT_FREQ" value="5000"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_eth.SPECIFY_IP" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_eth.SPECIFY_NETWORK_CARD" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_eth.STARTUP_USE_SWD" value="true"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_ser.ALWAYS_ERASE" value="false"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_ser.CYCLONE_IP" value=""/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_ser.DO_RESET_DELAY" value="false"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_ser.INTERFACE_PORT" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_ser.INTERFACE_PORT_STRING" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_ser.NETWORK_CARD_IP" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_ser.POWER_DOWN_DELAY" value="250"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_ser.POWER_OFF" value="false"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_ser.POWER_UP_DELAY" value="250"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_ser.PROVIDE_POWER" value="false"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_ser.REGULATOR_VOLTAGE" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_ser.RESET_DELAY" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_ser.SHIFT_FREQ" value="5000"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_ser.SPECIFY_IP" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_ser.SPECIFY_NETWORK_CARD" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_ser.STARTUP_USE_SWD" value="true"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_usb.ALWAYS_ERASE" value="false"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_usb.CYCLONE_IP" value=""/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_usb.DO_RESET_DELAY" value="false"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_usb.INTERFACE_PORT" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_usb.INTERFACE_PORT_STRING" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_usb.NETWORK_CARD_IP" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_usb.POWER_DOWN_DELAY" value="250"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_usb.POWER_OFF" value="false"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_usb.POWER_UP_DELAY" value="250"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_usb.PROVIDE_POWER" value="false"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_usb.REGULATOR_VOLTAGE" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_usb.RESET_DELAY" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_usb.SHIFT_FREQ" value="5000"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_usb.SPECIFY_IP" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_usb.SPECIFY_NETWORK_CARD" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.cyc_usb.STARTUP_USE_SWD" value="true"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.doConnectToRunning" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.doContinue" value="true"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.doFirstReset" value="true"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.doGdbServerAllocateConsole" value="true"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.doGdbServerAllocateSemihostingConsole" value="true"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.doGdbServerInitRegs" value="true"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.doGdbServerLocalOnly" value="true"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.doGdbServerSilent" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.doGdbServerVerifyDownload" value="true"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.doSecondReset" value="true"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.doStartGdbServer" value="true"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.enableFlashBreakpoints" value="true"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.enableSemihosting" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.enableSemihostingIoclientGdbClient" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.enableSemihostingIoclientTelnet" value="true"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.enableSwo" value="true"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.firstResetSpeed" value="30"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.firstResetType" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.gdbClientOtherCommands" value="set mem inaccessible-by-default off&#13;&#10;set tcp auto-retry on&#13;&#10;set tcp connect-timeout 30"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.gdbClientOtherOptions" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.gdbServerConnection" value="usb"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.gdbServerConnectionAddress" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.gdbServerDebugInterface" value="swd"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.gdbServerDeviceEndianness" value="little"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.gdbServerDeviceName" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.gdbServerDeviceSpeed" value="30"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.gdbServerExecutable" value="${jlink_path}/JLinkGDBServerCL"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.gdbServerGdbPortNumber" value="7224"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.gdbServerLog" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.gdbServerOther" value="-s"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.gdbServerSwoPortNumber" value="2332"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.gdbServerTelnetPortNumber" value="51794"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.interfaceSpeed" value="auto"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.ml.ALWAYS_ERASE" value="false"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.ml.CYCLONE_IP" value=""/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.ml.DO_RESET_DELAY" value="false"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.ml.INTERFACE_PORT" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.ml.INTERFACE_PORT_STRING" value="USB1"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.ml.NETWORK_CARD_IP" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.ml.POWER_DOWN_DELAY" value="250"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.ml.POWER_OFF" value="false"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.ml.POWER_UP_DELAY" value="1000"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.ml.PROVIDE_POWER" value="false"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.ml.REGULATOR_VOLTAGE" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.ml.RESET_DELAY" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.ml.SHIFT_FREQ" value="5000"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.ml.SPECIFY_IP" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.ml.SPECIFY_NETWORK_CARD" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.ml.STARTUP_USE_SWD" value="false"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.otherInitCommands" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.otherRunCommands" value=""/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.sda.ALWAYS_ERASE" value="false"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.sda.CYCLONE_IP" value=""/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.sda.DO_RESET_DELAY" value="false"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.sda.INTERFACE_PORT" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.sda.INTERFACE_PORT_STRING" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.sda.NETWORK_CARD_IP" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.sda.POWER_DOWN_DELAY" value=""/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.sda.POWER_OFF" value="false"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.sda.POWER_UP_DELAY" value=""/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.sda.PROVIDE_POWER" value="false"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.sda.REGULATOR_VOLTAGE" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.sda.RESET_DELAY" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.sda.SHIFT_FREQ" value="5000"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.sda.SPECIFY_IP" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.sda.SPECIFY_NETWORK_CARD" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.sda.STARTUP_USE_SWD" value="true"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.secondResetType" value=""/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.swoEnableTargetCpuFreq" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.swoEnableTargetPortMask" value="0x1"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.swoEnableTargetSwoFreq" value="0"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.trc_eth.ALWAYS_ERASE" value="false"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.trc_eth.CYCLONE_IP" value=""/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.trc_eth.DO_RESET_DELAY" value="false"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.trc_eth.INTERFACE_PORT" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.trc_eth.INTERFACE_PORT_STRING" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.trc_eth.NETWORK_CARD_IP" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.trc_eth.POWER_DOWN_DELAY" value="250"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.trc_eth.POWER_OFF" value="false"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.trc_eth.POWER_UP_DELAY" value="250"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.trc_eth.PROVIDE_POWER" value="false"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.trc_eth.REGULATOR_VOLTAGE" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.trc_eth.RESET_DELAY" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.trc_eth.SHIFT_FREQ" value="5000"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.trc_eth.SPECIFY_IP" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.trc_eth.SPECIFY_NETWORK_CARD" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.trc_eth.STARTUP_USE_SWD" value="true"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.trc_usb.ALWAYS_ERASE" value="false"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.trc_usb.CYCLONE_IP" value=""/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.trc_usb.DO_RESET_DELAY" value="false"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.trc_usb.INTERFACE_PORT" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.trc_usb.INTERFACE_PORT_STRING" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.trc_usb.NETWORK_CARD_IP" value=""/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.trc_usb.POWER_DOWN_DELAY" value="250"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.trc_usb.POWER_OFF" value="false"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.trc_usb.POWER_UP_DELAY" value="250"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.trc_usb.PROVIDE_POWER" value="false"/>
<intAttribute key="com.pemicro.debug.gdbjtag.pne.trc_usb.REGULATOR_VOLTAGE" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.trc_usb.RESET_DELAY" value="0"/>
<stringAttribute key="com.pemicro.debug.gdbjtag.pne.trc_usb.SHIFT_FREQ" value="5000"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.trc_usb.SPECIFY_IP" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.trc_usb.SPECIFY_NETWORK_CARD" value="false"/>
<booleanAttribute key="com.pemicro.debug.gdbjtag.pne.trc_usb.STARTUP_USE_SWD" value="true"/>
<stringAttribute key="org.eclipse.cdt.debug.gdbjtag.core.imageFileName" value=""/>
<stringAttribute key="org.eclipse.cdt.debug.gdbjtag.core.imageOffset" value=""/>
<stringAttribute key="org.eclipse.cdt.debug.gdbjtag.core.ipAddress" value="127.0.0.1"/>
<stringAttribute key="org.eclipse.cdt.debug.gdbjtag.core.jtagDevice" value="GNU ARM J-Link"/>
<booleanAttribute key="org.eclipse.cdt.debug.gdbjtag.core.loadImage" value="true"/>
<booleanAttribute key="org.eclipse.cdt.debug.gdbjtag.core.loadSymbols" value="true"/>
<stringAttribute key="org.eclipse.cdt.debug.gdbjtag.core.pcRegister" value=""/>
<intAttribute key="org.eclipse.cdt.debug.gdbjtag.core.portNumber" value="7224"/>
<booleanAttribute key="org.eclipse.cdt.debug.gdbjtag.core.setPcRegister" value="false"/>
<booleanAttribute key="org.eclipse.cdt.debug.gdbjtag.core.setResume" value="false"/>
<booleanAttribute key="org.eclipse.cdt.debug.gdbjtag.core.setStopAt" value="false"/>
<stringAttribute key="org.eclipse.cdt.debug.gdbjtag.core.stopAt" value="main"/>
<stringAttribute key="org.eclipse.cdt.debug.gdbjtag.core.symbolsFileName" value=""/>
<stringAttribute key="org.eclipse.cdt.debug.gdbjtag.core.symbolsOffset" value=""/>
<booleanAttribute key="org.eclipse.cdt.debug.gdbjtag.core.useFileForImage" value="false"/>
<booleanAttribute key="org.eclipse.cdt.debug.gdbjtag.core.useFileForSymbols" value="false"/>
<booleanAttribute key="org.eclipse.cdt.debug.gdbjtag.core.useProjBinaryForImage" value="true"/>
<booleanAttribute key="org.eclipse.cdt.debug.gdbjtag.core.useProjBinaryForSymbols" value="true"/>
<booleanAttribute key="org.eclipse.cdt.debug.gdbjtag.core.useRemoteTarget" value="true"/>
<stringAttribute key="org.eclipse.cdt.debug.mi.core.commandFactory" value="Standard (Windows)"/>
<stringAttribute key="org.eclipse.cdt.debug.mi.core.protocol" value="mi"/>
<booleanAttribute key="org.eclipse.cdt.debug.mi.core.verboseMode" value="false"/>
<stringAttribute key="org.eclipse.cdt.dsf.gdb.DEBUG_NAME" value="${cross_prefix}gdb${cross_suffix}"/>
<booleanAttribute key="org.eclipse.cdt.dsf.gdb.UPDATE_THREADLIST_ON_SUSPEND" value="false"/>
<intAttribute key="org.eclipse.cdt.launch.ATTR_BUILD_BEFORE_LAUNCH_ATTR" value="2"/>
<stringAttribute key="org.eclipse.cdt.launch.COREFILE_PATH" value=""/>
<stringAttribute key="org.eclipse.cdt.launch.PROGRAM_NAME" value="Debug\MyPWMAbstract.elf"/>
<stringAttribute key="org.eclipse.cdt.launch.PROJECT_ATTR" value="MyPWMAbstract"/>
<booleanAttribute key="org.eclipse.cdt.launch.PROJECT_BUILD_CONFIG_AUTO_ATTR" value="true"/>
<stringAttribute key="org.eclipse.cdt.launch.PROJECT_BUILD_CONFIG_ID_ATTR" value="ilg.gnuarmeclipse.managedbuild.cross.config.elf.debug.2113661177"/>
<listAttribute key="org.eclipse.debug.core.MAPPED_RESOURCE_PATHS">
<listEntry value="/MyPWMAbstract"/>
</listAttribute>
<listAttribute key="org.eclipse.debug.core.MAPPED_RESOURCE_TYPES">
<listEntry value="4"/>
</listAttribute>
<stringAttribute key="org.eclipse.dsf.launch.MEMORY_BLOCKS" value="&lt;?xml version=&quot;1.0&quot; encoding=&quot;UTF-8&quot; standalone=&quot;no&quot;?&gt;&#13;&#10;&lt;memoryBlockExpressionList context=&quot;reserved-for-future-use&quot;/&gt;&#13;&#10;"/>
<stringAttribute key="process_factory_id" value="org.eclipse.cdt.dsf.gdb.GdbProcessFactory"/>
</launchConfiguration>
2,144 次查看
BlackNight
So you have a hard fault.
I recommend that you have a look at
http://mcuoneclipse.com/2012/12/28/a-processor-expert-component-to-help-with-hard-faults/
Debugging Hard Faults on ARM Cortex-M | MCU on Eclipse
to get insights what is causing this.
Erich
2,143 次查看
artembilik
I understand you. Thanks.
2,143 次查看
artembilik
As well DPT swears that PE license file is not found if it can affect the operation of the components?
