Flashing Problems in KDS 3.2
2,012件の閲覧回数
vigneshbalaji
Senior Contributor I
    I am using KDS3.2. I used a project in a different system it is working well.But When I use it in this system then It shows me Errors like Connection Closed by GDB Server, Failed to execute MI command etc150233_150233.pngScreenshot (6).png150234_150234.pngScreenshot (5).png150235_150235.pngScreenshot (4).png
5 返答(返信)
1,626件の閲覧回数
Hello ,
I think the project of "sfs" is i send to you , i can download and debug it well on TRK-KEA128 board.
1) Please be sure the firmware of your board  from the computer management, does it j-link ?
take a screenshot about this to me :
2) Disable all of the breakpoints in your project before download.
3) You can also take a screenshot about the steps when you download .
Hope it helps
Alice
1,626件の閲覧回数
vigneshbalaji
Please take up this question on the new thread Flashing Problems in KDS 3.2?
1,626件の閲覧回数
vigneshbalaji
Hi Alice,
             I suspect The computer because I did things from other computer and same TRK-KEA128 Board it worked.
And Initially I tried with open SDA. I saw The Open SDA in Device Manager Also.
While Trying with Open SDA The Flashing Took very much longer that I have to cancel it, I have attached the Screenshot  of it in pic 1.Then Second Time it throwed an error for which also I have attached a Screenshot in pic 2.
I want to know the exact problem behind this and to solve it.
1,626件の閲覧回数
vigneshbalaji
I am getting a Debugger settings like this the port is not selected.Screenshot (31).png
1,626件の閲覧回数
When you use the Open SDA to debug , please configure the debugger as this :
Hope it helps
Alice
