Error in services launch sequence.GDB prompt not read
3,221 次查看
manish2789
Hello ,
         I am using Kinetis Design Studio [beta] version 1.0.1 with frdm board (KL25Z). .I have successfully installed KDS and launch it on Ubuntu 13.10. I have write code for blinking RGB LED simutenously.I have followed steps in Quickstart Guide for KDS v1.0.1 beta for setting debug environment  using OpenOCD also installed driver for OpenOCD as per instrucion in maual.But I'm getting following problems
1. Debugger didn't launch even if I followed all instruction in  Quickstart Guide for KDS v1.0.1 beta
2.When I'm tring to flash the code after pressing flash button it will get following error
       Error in services launch sequence GDB prompt not read
so please guide me how to reslove this problems and how to flash code after this.
I am attaching error screenshot with this post.
Thanks and Regards
Manish Baing
标记 (4)
1,869 次查看
BlackNight
I believe there is something missing in your debug configuration settings, or that your board does not have the CMSIS-DAP loaded.
Can you share a screenshot of your launch configuration?
Erich
