Error in make(mcu on eclipse)
2,006 次查看
vigneshbalaji
Senior Contributor I
    I am getting Error 2 in the console.I have attached the Screenshots also and the project also.
I followed Erich's post but I am not able to get it right https://mcuoneclipse.com/2013/07/21/diy-free-toolchain-for-kinetis-part-2-eclipse-ide/
标记 (2)
1,858 次查看
ZhangJennie
please download the project from GitHub here:
mcuoneclipse/Examples/Eclipse/FRDM-KL25Z/FRDM-KL25Z_Blink at master · ErichStyger/mcuoneclipse · Git...
How does it works with this project?
Jennie Zhang
1,858 次查看
vigneshbalaji
Hi Zhang,
               The project link which you have given is for KL25Z but I am using KEA-128. if you can provide me an example of KEA-128 on Eclipse IDE it will be great :smileyhappy:.
1,858 次查看
ZhangJennie
the set of eclipse demo code was developed by Professor Erich Styger, the demo code is only available for K64/K25/K20/K60.
https://github.com/ErichStyger/mcuoneclipse/tree/master/Examples/Eclipse
user who uses other target please develop the code with referring those samples.
Hope this helps!
Jennie Zhang
