Error in final launch sequence. Failed to execute MI command: -target-select remote localhost:7224
4,060 次查看
armaram
We are working with KDS 3.0.0 and KSDK 1.3.0 on the FRDM-KL03Z dev brd and frequently keep encountering this error. We try all things like resetting the board, disconnecting it, restarting KDS sometime that helps but this time nothing seems to be working.
Error message from debugger back end:
Remote communication error.  Target disconnected.: No error.
We are stuck with this error and cannot move forward. Any guidance will be of great help?
Arvind
3,077 次查看
Carlos_Mendoza
Hi Arvind,
Please take a look to the following post created by our colleague Erich Styger, it gives some trouble shooting tips for debugging:
GDB Debugging with Kinetis Design Studio
Let us know if it helps!
Carlos Mendoza
Technical Support Engineer
3,078 次查看
Carlos_Mendoza
Hi Arvind,
Carlos Mendoza
3,077 次查看
armaram
Thank you Carlos, it was helpful.
Arvind
