Encryption with K22
Encryption with K22
937 次查看
burgeh
Greetings again,
I am about to look into the realm of encrypting my sending data. I am using the K22FN256LH12 microcontroller on a custom board, with KDS v3.2 and Processor Expert.
I don't have much knowledge on this topic and I am looking for suggestions or components that I could use to encrypt the data that I send from a cat m1 modem to a server using a socket dial and http post command. Any suggestions would be a appreciated!
808 次查看
ZhangJennie
I don't think processor expert has encryption component.
You can use or refer SDK wolfssl software component.
Welcome | MCUXpresso SDK Builder
The latest SDK 2.4.1 doesn't support KDS now. I suggest you use MCUXpresso IDE instead.
Jennie Zhang
809 次查看
ZhangJennie
Jennie Zhang
