Thanks Eric:
I've always appreciated how well you support this community when I post
something for my full time job. It's nice to see when I'm posting for
myself you are the same helpful guy.
I tried the PTA registers in my FRDM-K64F through the OpenSDA USB port.
Unfortunately, I do not get the same result as you. I still see the
name turn green in the KDS tool, but nothing is filled in for the hex or
binary columns regarding the register's data. Additionally the data
that appears to be going to the OpenSDA port--(when viewing the
transactions in the Console window) appear to be returning a negative
1. I'm assuming the reset column is what the register will be set to
out of reset and not the current value, right?
I have tried upgrading the KDS embsysregview tool from the eclipse
marketplace and the sourceforge trees. Unfortunately, KDS would not
update even when trying to do this as the root user. I'd be happy to
try other locations if it will fix this issue.
As for switching to MCUXpresso, I'd be happy to install this tool if NXP
would create an RPM version of the tool. Without this, I cannot install
it on my Centos 7.4 version I am using without a lot of extra work I
cannot spare right now. Additionally, windows is not really an option
for our development environment.
Any other thoughts or ideas for how to move forward are greatly appreciated.
Mike
